YaCy Index Accretion
If you do some crawls and develop an index, what happens if you must take your instance offline permanently?
Will all the work completed and held in the data folder be lost to the YaCy network?
Is there a way to contribute one’s efforts to the network before abandoning the instance? For example, is there a way to “upload the data folder and glue it to a main YaCy index”?
