Torworld in 2025
Hello, I was reading the docs about different P2P network definitions, i came across ‘torworld’, which is meant for tor hidden service crawlers (onion-only YaCy).
I would like to find out how to connect to ‘torworld’ or something similar (YaCy P2P network of onion-only crawlers)
I found it here:
From my searches i could not find any up-to-date info on this.
The problem is that the bootstrap URL’s for ‘torworld’ use hidden service v2, they are now completely replaced with V3. (the tor project said they stop working after sometime in 2021, i doubt even the directory services work with v2 anymore, likely a dead end to try v2).
Given that issue, how could i connect to ‘torworld’ or similar in 2025? I assume there are some YaCy search engines out there that are onion-only.
Update: Found this relevant for advice on defining new networks:
