Support peer-to-peer index transmission (DHT RWI index)
Hi all :slight_smile:
I spent a lot of time deleting sites and creating blacklists.
This morning when I woke my index was full of sites I had deleted and created blacklists for.
They came in via “Index Receive”.
(my fault, should have selected reject)
Is there anyway to mass delete? I have tried using regular expressions at IndexDeletion_p but none have worked.
To answer my question, to bulk remove “.ru”.
I used .*.ru\/.* as the regex. It appears to have worked. I don’t recommend anyone tries it in case it has unforeseen consequences.
If you do give it a go, don’t blame me for any damage. :stuck_out_tongue:
