Routing through CNAT
My broadband connection is behind a carrier grade NAT. So every customer of the ISP has the same external IP address, and I have no way of port forwarding or a DMZ.
How might I configure this to share my peer?
I was thinking a tor hidden service, or maybe SSH with reverse proxy - any views?
Cheers
if you have the option of running a ssh tunnel on a host with public ip, you can run:
ssh -f -R remotehost.org:8090:localhost:8090 remotelogin@remotehost.org -N
and create tunnel to remotehost.org, port 8090.
i use that and it works.
set the remote host IP as “StaticIP” in /Settings_p.html?page=ServerAccess then.
