RFC: docs: Index distribution in YaCy
I’m trying to understand YaCy and as I go through it, I take notes, which may be a documentation in the future.
Following text describes the Index distribution in YaCy.
I’m sure there is a lot of more experienced users.
Could you please check it and tell me, if I’m wrong somewhere, before I publish it?
There is also a lot of questions I’m not sure with, marked with ???.
If you know the answer, please write in this topic!
thanks!
There are two indices in each YaCy instance.
First one is horizontal (??) - a solr index, which you use for a local instance search.
The second one is vertical (??) called RWI (Reverse Word Index). In this
index, for every keyword, urls of pages containing that particular keyword
are stored.
RWI is distributed over whole network (e.g. default ‘freeworld’), creating
the global Distributed Hash Table (DHT).
If you take a look into your log, you can see every each and now entries like:
I 2023/11/19 15:12:01 INDEX-TRANSFER-DISPATCHER * Index transfer of 5 references for terms [ AIYDnOXpfXHp ..] and 7 URLs to peer agent-yacyname-ufe-80:Os871898Kx7Z in 0 seconds successful (21 words/s)
That means, your instance constantly go through yours RWIs, select some
of the words, transfer them to other hosts and as they had transfered,
deletes them from local RWI.
??? WHEN SEARCH, what is went through? solr? rwi?
??? WHEN SOMEONE searches my instance remotely, are the results sent as
RWIs? are they stored remotely then? and on my instance as well?
You can decide if you want to sent the RWIs and whether to receive them by
switching on and off both “Index Distribution” and “Index Receive” in
/ConfigNetwork_p.html, Peer-to-Peer Mode.
Respective config settings are:
allowDistributeIndex=true
allowReceiveIndex=true
Storage and performance
As you crawl, pages are indexed in the solr, and at the same time, RWIs are
created.
Unlike of solr index, stored in a database, RWIs are stored in files located
in DATA/INDEX/freeworld/SEGMENTS/default/text.index.* , managed by system
called kelondro.
During startup and shutdown you can see a lot of entries such as:
I 2023/11/19 16:48:57 HeapReader * wrote a dump for the 3354794 index entries of text.index.20231020165340362.blob in 531 milliseconds.
I 2023/11/19 16:48:57 HeapReader * close HeapFile text.index.20231020165340362.blob; trace: net.yacy.kelondro.blob.HeapModifier.close(HeapModifier.java:82) -> net.yacy.kelondro.blob.ArrayStack.close(ArrayStack.java:906) -> net.yacy.kelondro.rwi.ReferenceContainerArray.close(ReferenceContainerArray.java:79) -> net.yacy.kelondro.rwi.IndexCell.close(IndexCell.java:606) -> net.yacy.search.index.Segment.close(Segment.java:508) -> net.yacy.search.Switchboard.close(Switchboard.java:2012) -> net.yacy.yacy.startup(yacy.java:404) -> net.yacy.yacy.main(yacy.java:832)
I 2023/11/19 16:48:57 HeapReader * wrote a dump for the 5176 gap entries of text.index.20231020212118698.blob in 1 milliseconds
meaning that parts of the index (segments) are merged, compressed etc. This
can be time consuming and prolonging the restart. The more RWIs, the more
work to do.
They also occupy certain ammount of RAM, which you can inspect in /PerformanceMemory_p.html
at the end of “Object Index Caches” table (e.g. Total Mem: 4,980.06 MB).
Merging the segments is done also in background. If you crawl a lot, after
pausing the crawl, you still observe a lot of IO and you can see the “teeth”
in the Performance memory graph, as backend is merging the segments, until
it stays still and the RAM curve is not rising anymore. Everything is clean
and tidy now.
??? QUESTION - what is the clue to merge the files? when it’s done and
why?
After deleting a local RWI database (either in “Index Administration >
Cleanup > Delete RWI Index” or just deleting the text.index.* files while
your instance is stoped), you can observe quite a drop in RAM consumption
and increase of speed of startup, shutdown and search. Some people prefer
to delete the RWIs regulary from that reason, but on the other hand, their
presence is the basic of distributed P2P search.
Sometimes the RWIs even fill out all the RAM allocated for YaCy, resulting
in frequent GC (a Java process of cleaning the memory, performance expenssive)
and, later on, even in filling the RAM in a way that instance would break. The
cure is easy then: just delete the RWI files and start YaCy again.
The question is, if RWIs are implemented efficiently and whether they couldn’t be
implemented in a way, that doesn’t degrade the performance of local peer in
such huge degree.
??? ARE RWIs generated also when importing the surrogates or the older
exported indices?
RWI transport
There are 3 ways of RWI transport to another host:
  1. indexDistribution: which is done periodically if you have enabled
    Index Distribution via /IndexControl_p.html
  2. indexTransfer: which can be used to transfer the whole index of a peer
    this can be started via /IndexTransfer_p.html
  3. indexControl: which can be triggered manually via /IndexControl_p.html to
    transfer a chosen subset of the peer index
In regular RWI distribution, RWIs are selected from the files, chunked,
sent to randomly selected hosts and deleted from local index.
??? QUESTION - how are selected? from the latest? if so, wouldn’t be
possible to set a configuration option to start the selection from oldest?
Speculation: As my instance is usually busy with sending the latest ones,
the oldest are never sent.
You can see the number of yours RWI both in Crawler Monitor (RWIs - P2P
Chunks) and Peer-to-Peer Network (/Network.html). There, you can also watch
yours inbound and outbound transfers as green or red lines, respectively.
Tuning the transport
If you are not satisfied with huge amount of yours RWIs, you can tune some
of the config file settings to sent them away more swiftly:
20_dhtdistribution_idlesleep=30000
the time waiting before next chunk is transfered. lowering means
transfering chunks more frequently
20_dhtdistribution_busysleep=15000
??? not sure with this
20_dhtdistribution_memprereq=12582912
don’t do the distribution when RAM is lower than this number
20_dhtdistribution_loadprereq=2.0
don’t do the distribution when load is lower than this number. increase to
do the distribution despite the higher load
The sizes of chunks can be changed in the following settings:
indexDistribution.minChunkSize = 10
indexDistribution.maxChunkSize = 1000
indexDistribution.startChunkSize = 200
??? Not sure, if they actually work. Even when setting minChunkSize to
larger value, chunks with just a few URLs are still sent.
Furthermore in network definition, there is a definition of “redundancy”,
which means, how many identical copies of your RWI are sent to other hosts.
network.unit.dhtredundancy.senior=3
network.unit.dhtredundancy.junor=1
Above default setting means that 3 copies of every RWI is sent to other
host (before they’re deleted localy) when you’re senior peer, and just one
when you’re junior.
??? What is the exponent?
network.unit.dht.partitionExponent=4
Technical details
In detail, source codes describe the transfer process in
Dispatcher.java as:
The dispatcher class accumulates indexContainerCache objects before they are transfered
to other peers. A dispatcher holds several of such caches to enhance the transmission process.
Before a RWI is sent, the following process is applied:
  1. A number of RWIs are selected and accumulated.
    When they are selected, they are removed from the index,
  2. the RWI collection is split into a number of partitions according to the vertical DHT,
  3. the split RWIs are enqueued as Entry object in the write buffer of the dispatcher,
  4. more entries may be enqueued to the dispatcher and entries with the same
    primary target are accumulated to the same buffer entry,
  5. the largest entries are selected from the dispatcher write buffer and enqueued to the ‘next’ array
    which means that they are ready for transmission,
  6. the dispatcher takes some of the entries in the next queue and initiates
    transmission to other peers concurrently. As much transmissions are
    initiated concurrently as the redundancy factor,
  7. a transmission thread executes the entry transmission,
  8. the transmission thread initiates another transmission in case that it fails,
  9. when the wanted number of redundant peers have received the entries,
    they are removed from the next queue.
see also:
A in-detail description is here: https://yacy.net/material/Description_of_the_YaCy_Distributed_Web_Search_Engine_Herrmann_Ning_Diaz_Preneel_ESAT_KULeuven_COSIC_article-2459.pdf
Thanks, @orbiter!
Still, some questions remain:
  • WHEN SOMEONE searches my instance remotely, are the results sent as
  • what is the clue to merge RWI blob files? when it’s done and why?
  • ARE RWIs generated also when importing the surrogates or the older
    exported indices?
  • how are RWI selected for transfer? from the latest? if so, wouldn’t be
thanks for reply!
Yes, the remote search extracts the corresponding Index Entry Details from the RWI and they become part of your own RWI - so they are used for your search results and stored in your own index.
RWI merges are done constantly in a similar fashion as lucene does that. Two files are merged into one new. There is a threshold when this has to be done but I can’t remember what the exact rules are.
Yes, always - if they are generated at all (there must be a flag somewhere). Indexing in P2P mode should always cause the writing of two indexes, Solr and RWIs. RWIs dissolve during index transmission, Solr indexes stay.
No the entries are selected by DHT targets. Age is not relevant. As far as I remember the DHT target (another peer) is selected randomly and then index entries are selected for transfer. The rule is, that exactly those index entries are selected for transfer which I would expect to be at the peer when I search using the same DHT rule.
thanks a lot, michael!
Finised and published: RWI Index Distribution. PR.
