roamn
28 May 2024 02:10
1
My QB64 program was asking Yacy to search ~100 times a second.
I am also testing java options.
JAVA_ARGS="-server -Djava.awt.headless=true -Dfile.encoding=UTF-8 -XX:ReservedCodeCacheSize=16m";
With httpd session pool at 200 I can overload my peer’s memory very quickly.
After httpd session pool at 20 Its a lot harder to overload my peers’s memory.
There is also an issue of yacy not saving httpd session pool settings.
If you change the setting you have to do it on each fresh start or restart.
https://github.com/yacy/yacy_search_server/issues/647
YaCy Stress Testing & Optimization — 12-Month Benchmark Overview
Overview:
Over the past 12 months, I have conducted extensive stress testing on YaCy using various configurations and backend setups, including RAID 5, RAM drives, and JVM tuning. The goal was to evaluate response time under burst load conditions , identify potential memory leaks, and assess the impact of JVM updates on system stability.
System Setup:
Server: HP DL360 Gen8
RAM: 384 GB ECC
Java: Amazon Corretto 21
Storage Backends:
RAID 5
RAMDisk (tmpfs
for /var and /var/tmp)
Issue Encountered:
During testing, the Java process crashed, leaving behind a diagnostic log.
Upon inspection, the crash appeared to be related to a A fatal error has been detected by the Java Runtime Environment: , causing memory parsing issues.
The issue was reported to Amazon Corretto 21 on GitHub:
Suggested Resolution: Update to Amazon Corretto 21.0.7.6-1 .
Resolution & Testing:
After updating to 21.0.7.6-1 , I ran several test scripts, including:
Python Burst Script: JSON API search at 1 kHz with 10s cooldown
QB64 Custom Program: High-frequency search testing at 15 Hz and 100 Hz
Findings:
Memory usage decreased slightly with the JVM update, likely due to improved garbage collection and heap management.
RAMDisk significantly improved response times, reducing disk I/O contention.
RAID 5 backend remained the primary source of latency spikes, particularly under 100 Hz sustained query load.
Java Options:
To further optimize JVM performance, the following Java options were applied:
JAVA_ARGS="-server -Djava.awt.headless=true -Dfile.encoding=UTF-8"
JAVA_ARGS="-XX:+UseZGC -XX:ZUncommitDelay=60 -XX:+UseLargePages $JAVA_ARGS"
JAVA_ARGS="-XX:+PerfDisableSharedMem $JAVA_ARGS"
Explanation:
-XX:+UseZGC
— Enables the Z Garbage Collector for rapid, low-latency memory management.
— Frees unused memory after 60 seconds of inactivity.
-XX:+UseLargePages
— Reduces TLB misses, improving memory access efficiency.
— Disables unnecessary shared memory, minimizing contention.
Benchmark Data & Analysis:
Visuals:
After starting 4000 queries 100 hz
At 1 min
note cpu avg 392
22 k searches Hz dropped
49 k searches 9 min
My stress tester pc Locked me out and took me to the logon screen. Ubuntu 24.04.
Next Steps:
Further testing with increased thread pool size and advanced GC tuning (ZGC
with string deduplication).
Investigate potential I/O scheduler optimizations to reduce disk wait states under concurrent load.
