So I’ve installed yacy on arch with yay -S yacy-git, but I’m persistently getting 0 search results
I’ve looked up some solutions, and found that users had a similar issue related to database migration, but this doesn’t seem to apply to me, since this is on new install
I am connected to the network.
Here is the log of the search:
I 2024/10/14 13:04:55 NoticedURL * CLEARING ALL STACKS
I 2024/10/14 13:04:55 SWITCHBOARD * cleanup post-processed 0 documents
I 2024/10/14 13:04:55 SWITCHBOARD * postprocessing deactivated: constraints violated
I 2024/10/14 13:04:55 SWITCHBOARD * postprocessing deactivated: too high load (12.1484375) > 2.5, to force change field postprocessing.maximum_load
I 2024/10/14 13:04:55 SWITCHBOARD * postprocessing deactivated: no enough ram (440491344), needed 536870912, to force change field postprocessing.minimum_ram
I 2024/10/14 13:04:55 SWITCHBOARD * postprocessing deactivated: no reference index avilable; activate citation index or webgraph
I 2024/10/14 13:04:55 SWITCHBOARD * postprocessing deactivated: field process_sxt is not enabled
I 2024/10/14 13:04:55 RESOURCE OBSERVER * resources ok
I 2024/10/14 13:04:55 NETWORK * rulebasedUpdateInfo: not an automatic update selected
I 2024/10/14 13:04:46 Fulltext * HOT DUMP dump path = /usr/share/java/yacy/DATA/ARCHIVE
I 2024/10/14 13:03:51 FILEHANDLER * Processing of multipart/form-data request failed. java.util.concurrent.TimeoutException: Idle timeout expired: 9000/9000 ms
I 2024/10/14 13:03:40 FILEHANDLER * Processing of multipart/form-data request failed. java.util.concurrent.TimeoutException: Idle timeout expired: 9000/9000 ms
I 2024/10/14 13:03:36 FILEHANDLER * Processing of multipart/form-data request failed. java.util.concurrent.TimeoutException: Idle timeout expired: 9001/9000 ms
I 2024/10/14 13:03:00 FILEHANDLER * Processing of multipart/form-data request failed. java.util.concurrent.TimeoutException: Idle timeout expired: 9001/9000 ms
I 2024/10/14 13:02:59 FILEHANDLER * Processing of multipart/form-data request failed. java.util.concurrent.TimeoutException: Idle timeout expired: 9001/9000 ms
I 2024/10/14 13:02:55 FILEHANDLER * Processing of multipart/form-data request failed. java.util.concurrent.TimeoutException: Idle timeout expired: 9000/9000 ms
I 2024/10/14 13:02:47 DidYouMean * found 0 unsorted terms, returned 0 sorted suggestions; execution time: 12ms; timeout : 100ms.
I 2024/10/14 13:02:47 NETWORK * SEARCH (solr), returned 0 out of 0 documents from peer wgfESHNQJKvD:agent-risaneg-ufe-16 query = defType=edismax&qf=url_paths_sxt^3.0+synonyms_sxt^0.5+title^5.0+text_t^1.0+host_s^6.0+h1_txt^5.0+url_file_name_tokens_t^4.0+h2_txt^3.0+keywords^2.0+description_txt^1.5+author^1.0&start=0&rows=10&fq=httpstatus_i:200&fq=-content_type:(image/)&fq=-url_file_ext_s:(jpg+OR+png+OR+gif)&facet.method=enum&f.url_file_ext_s.facet.limit=100000&f.language_s.facet.limit=100000&fl=,score&q=“test”&bq=crawldepth_i:0^0.8&bq=crawldepth_i:1^0.4&hl=true&hl.fragsize=220&hl.simple.post=&hl.simple.pre=&hl.snippets=5&hl.fl=description_txt&hl.fl=h4_txt&hl.fl=h3_txt&hl.fl=h2_txt&hl.fl=h1_txt&hl.fl=text_t
I 2024/10/14 13:02:47 DHT * preparing remote search: shortmem=false, indexingQueueSize=0, redundancy=2, minage=3, dhtPeers=32, robinsonpeers=16, health: load() > 2.0
I 2024/10/14 13:02:47 DHT * selectPeers/extra: y7mUdSzVO-NO:agent-rosigep-ufe-32, 64320358 URLs LARGE-SIZE
I 2024/10/14 13:02:47 DHT * selectPeers/extra: pqWHC1w5vQ_e:abydos, 5552181 URLs LARGE-SIZE
I 2024/10/14 13:02:47 DHT * selectPeers/extra: 8heoAko7EQxA:agent-bihukih-ufe-1461, 6698646 URLs LARGE-SIZE
I 2024/10/14 13:02:47 DHT * selectPeers/extra: sCSlwlgqgBJ-:sixcooler3, 77631658 URLs LARGE-SIZE
I 2024/10/14 13:02:47 DHT * selectPeers/extra: TwI6dBR9xUWl:agent-gilebod-ufe-14, 1686 URLs ROBINSON
I 2024/10/14 13:02:47 DHT * selectPeers/extra: zbVw-HbOb_jH:zoll_report, 23950184 URLs LARGE-SIZE
I 2024/10/14 13:02:47 DHT * selectPeers/extra: k4djMwySvbvy:agent-hefelok-ufe-48, 20043662 URLs LARGE-SIZE
I 2024/10/14 13:02:47 DHT * selectPeers/extra: iFmGgvQkawYL:agent-sikokel-ufe-63, 22930081 URLs LARGE-SIZE
I 2024/10/14 13:02:47 DHT * selectPeers/extra: knGjSsXqKc-o:lilnick-001, 4 URLs NODE
I 2024/10/14 13:02:47 DHT * selectPeers/extra: O_TCpVz-g9pZ:agent-chiyoda-ufe-23, 29464663 URLs LARGE-SIZE ROBINSON
I 2024/10/14 13:02:47 DHT * selectPeers/extra: NZugE_kufgsN:PraetorNormindex, 20514791 URLs LARGE-SIZE ROBINSON NODE
I 2024/10/14 13:02:47 DHT * selectPeers/extra: 1_DVU5Jj03dn:agent-tobisob-ufe-20, 33962995 URLs LARGE-SIZE
I 2024/10/14 13:02:47 DHT * selectPeers/extra: wBc8expdk0-h:yacy-home-v16-de, 47086804 URLs LARGE-SIZE
I 2024/10/14 13:02:47 DHT * selectPeers/extra: ojB3JX7OX9z2:agent-tesulut-ufe-22, 11615881 URLs LARGE-SIZE
I 2024/10/14 13:02:47 DHT * selectPeers/extra: x7bcuz1wLHZr:agent-c2f6e2ff-ufe-31, 15955123 URLs LARGE-SIZE
I 2024/10/14 13:02:47 DHT * selectPeers/extra: BzyR0ydAqUl2:agent-fbxl-yacy, 18393270 URLs LARGE-SIZE ROBINSON
I 2024/10/14 13:02:47 EmbeddedSolrConnector.getResponseByParams * QUERY: defType=edismax&q=title:“test”^1000.0 text_t:test~&start=0&rows=30&hl=true&hl.simple.pre=&hl.simple.post=&hl.snippets=5&hl.fl=text_t&timeAllowed=64
I 2024/10/14 13:02:47 EmbeddedSolrConnector.getResponseByParams * QUERY: defType=edismax&qf=url_paths_sxt^3.0 synonyms_sxt^0.5 title^5.0 text_t^1.0 host_s^6.0 h1_txt^5.0 url_file_name_tokens_t^4.0 h2_txt^3.0 keywords^2.0 description_txt^1.5 author^1.0&start=0&rows=10&fq=httpstatus_i:200&fq=-content_type:(image/)&fq=-url_file_ext_s:(jpg OR png OR gif)&facet=true&facet.mincount=1&facet.limit=100&facet.sort=count&facet.method=enum&facet.field={!ex=url_file_ext_s}url_file_ext_s&facet.field={!ex=author_sxt}author_sxt&facet.field={!ex=host_s}host_s&facet.field={!ex=language_s}language_s&facet.field={!ex=url_protocol_s}url_protocol_s&f.url_file_ext_s.facet.limit=100000&f.language_s.facet.limit=100000&fl=,score&q=“test”&bq=crawldepth_i:0^0.8&bq=crawldepth_i:1^0.4&hl=true&hl.fragsize=220&hl.simple.post=&hl.simple.pre=&hl.snippets=5&hl.fl=description_txt&hl.fl=h4_txt&hl.fl=h3_txt&hl.fl=h2_txt&hl.fl=h1_txt&hl.fl=text_t
I 2024/10/14 13:02:47 LOCAL_SEARCH * EXIT WORD SEARCH: test - local_rwi_available(0), local_rwi_stored(0), remote_rwi_available(0), remote_rwi_stored(0), remote_rwi_peerCount(0), local_solr_evicted(0), local_solr_stored(0), remote_solr_available(0), remote_solr_stored(0), remote_solr_peerCount(0), 2 ms
I 2024/10/14 13:02:47 Protocol * SOLR QUERY: defType=edismax&qf=url_paths_sxt^3.0+synonyms_sxt^0.5+title^5.0+text_t^1.0+host_s^6.0+h1_txt^5.0+url_file_name_tokens_t^4.0+h2_txt^3.0+keywords^2.0+description_txt^1.5+author^1.0&start=0&rows=10&fq=httpstatus_i:200&fq=-content_type:(image/)&fq=-url_file_ext_s:(jpg+OR+png+OR+gif)&facet=true&facet.mincount=1&facet.limit=100&facet.sort=count&facet.method=enum&facet.field={!ex=url_file_ext_s}url_file_ext_s&facet.field={!ex=author_sxt}author_sxt&facet.field={!ex=host_s}host_s&facet.field={!ex=language_s}language_s&facet.field={!ex=url_protocol_s}url_protocol_s&f.url_file_ext_s.facet.limit=100000&f.language_s.facet.limit=100000&fl=,score&q=“test”&bq=crawldepth_i:0^0.8&bq=crawldepth_i:1^0.4&hl=true&hl.fragsize=220&hl.simple.post=&hl.simple.pre=&hl.snippets=5&hl.fl=description_txt&hl.fl=h4_txt&hl.fl=h3_txt&hl.fl=h2_txt&hl.fl=h1_txt&hl.fl=text_t
I 2024/10/14 13:02:47 SearchEventCache * getEvent: 0 in cache
I 2024/10/14 13:02:47 LOCAL_SEARCH * INIT WORD SEARCH: test:CY9rzUYh03PK - 10 links to be computed, 10 lines to be displayed
Any suggestions how I can make this work?
