HTTPS is enabled but I don't see any peer-to-peer connection to it
I have a few day old node and everything seems to work smoothly. I have installed certbot and when I connect in https to my interface, everything works fine. I set up the seed sharing and the network acknoledge my node as Principal. I use the docker version 1.940/3ede322f5.
However, when I look I my web traffic, I don’t see any connection from a peer that is through https. Everything goes through http. If I close the http port, YaCy tells me I’m isolated. That’s congruent with the fact that, in the peer-to-peer table (/Network.html?page=1&maxCount=1000), I don’t have the little lock near the node name.
But I don’t understand why:
  • I checked the box to activate SSL
  • My internet box is forwarding 80, 8090 to the frontend proxy on the http port and 443 and 8443 to ssl port (I use vhosts)
  • YaCy can be reached from outside while adressing 8090 (normal), 443 (SSL), 8443 (SSL). 80 will redirect to 443, most of the time this is for human users.
  • I set up, in the server access page (/Settings_p.html?page=ServerAccess), * as a IP filter, my domain name as a static IP (because I have a stable domain name but a dynamic ip), my public port was set to 8090 and then 8443 but neither change anything. I didn’t change fileHost (localpeerr). My internal port are still 8090 and 8443.
I don’t know what I miss very few nodes have the little lock and I guess many other would like to have it.
Can you please help me to setup encrypted communication correctly?
Hi, and thanks for the report, it seems diligent!
how did you connect that with yacy?
both in /ConfigPortal_p.html Remote search encryption and /ConfigNetwork_p.html Protocol operations encryption, right?
In fact, I’m not sure, how does that work in my instance, have to check the ssl traffic. How did you check, whith tcpdump?
I meant that, of course, I execute YaCy behind a nginx instance that blocks bad ips and such (it’s also running crowdsec). So YaCy is a backend for nginx. Depending of the port nginx do a http or a https forwarding.
Nginx is the bearer of the let’s encrypt certificate and, when passing to YaCy it will just ignore the fact that the YaCy certificate is self-signed because I told it to ignore that.
So I run certbot for nginx. Pretty standard stuff.
To check for the https traffic, I simply look at my nginx logs that I customized to add scheme and port. The first tells me if https was asked and the second tells me on which port the connection occurs.
From the outside, I can reach the YaCy instance in https. But no peer seems to try. I guess that’s because, in the p2p list I do not have the lock besides the name so the other peers don’t try.
I hope the nodes don’t try to do a IP->name check because I use a dynamic DNS and therfore they would have the name given by my provider instead of the servername.
