How to search them all together?
It is newbie here.
When I use YaCy to search something in the web it looks like YaCy is giving me everything about each word I gave it. For example, if I place “big purple dog“ in the search field then YaCy gives me links to the pages with “big”, with “purple” and with “dog”.
How can I make it search pages which have all the words together ?
You want stronger search that obeys your query. I also am disappointed that many pages come up in the search results containing only one of the keywords entered. However, there is a way to achieve more compliant results, if you are willing to craft a query in the URL itself.
Example: Today, I want to learn about…
the law signed by Barack Obama in 2011 that authorizes the detainment of American citizens by the US military without a trial or due process, called the National Defense Authorization Act (NDAA).
I will choose two keywords:
Obama
NDAA
Those keywords should be on the same page, not only one or the other, but both. Here is the search I used:
http://141.98.154.239:8090/solr/select?q=text_t:obama%20AND%20text_t:NDAA&rows=10&wt=json
The result: I found pages that included both keywords. A solr query is more powerful than using the default search web page.
You can append the solr query to your peer’s IP address, or to another peer. The search is local only and does not use the global search. So, your results depend on the quality of the single peer’s crawl data.
You could try appending this query to your desired peer IP address:
/solr/select?q=text_t:KeywordOne%20AND%20text_t:KeywordTwo&rows=10&wt=json
I do see this as well. The idea of entering multiple terms, is to take them al into consideration when the search is done.
what I miss is using a operators (AND, OR, NOT, NEAR…) in the search field. they are discarded as stopwords and not used as operators. see also issue #342
Hi, I have the same experience.
I like the trick from ExploreTruth, I’m going to try it.
Another one could be useful for you.
You can use the inurl:keyword syntaxe to have at least the main keyword in the result. That work well when I search technical dev documentation. I that work with the network too.
In general I think that it work well with topic with official web site.
So instead of typing vuejs event managment, I type inurl:vuejs event managment.
I hope that help.
