… that happened.
The repo is cloned via git clone github ... yacy/ --depth 1, to reduce download time and disk space, in case that matters.
Buildfile: /home/parnikkapore/Documents/progfiles/yacy/build.xml
clean:
[delete] Deleting: /home/parnikkapore/Documents/progfiles/yacy/libbuild/GitRevTask.jar
buildGitRevTask:
[javac] Compiling 1 source file
[jar] Building jar: /home/parnikkapore/Documents/progfiles/yacy/libbuild/GitRevTask.jar
determineGitRevision:
[gitRev] SLF4J: Failed to load class "org.slf4j.impl.StaticLoggerBinder".
[gitRev] SLF4J: Defaulting to no-operation (NOP) logger implementation
[gitRev] SLF4J: See http://www.slf4j.org/codes.html#StaticLoggerBinder for further details.
BUILD FAILED
/home/parnikkapore/Documents/progfiles/yacy/build.xml:114: org.eclipse.jgit.errors.RevWalkException: Walk failure.
at org.eclipse.jgit.revwalk.RevWalk.iterator(RevWalk.java:1324)
at GitRevTask.execute(Unknown Source)
at org.apache.tools.ant.UnknownElement.execute(UnknownElement.java:292)
at jdk.internal.reflect.GeneratedMethodAccessor4.invoke(Unknown Source)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:566)
at org.apache.tools.ant.dispatch.DispatchUtils.execute(DispatchUtils.java:99)
at org.apache.tools.ant.Task.perform(Task.java:350)
at org.apache.tools.ant.Target.execute(Target.java:449)
at org.apache.tools.ant.Target.performTasks(Target.java:470)
at org.apache.tools.ant.Project.executeSortedTargets(Project.java:1388)
at org.apache.tools.ant.Project.executeTarget(Project.java:1361)
at org.apache.tools.ant.helper.DefaultExecutor.executeTargets(DefaultExecutor.java:41)
at org.apache.tools.ant.Project.executeTargets(Project.java:1251)
at org.apache.tools.ant.Main.runBuild(Main.java:834)
at org.apache.tools.ant.Main.startAnt(Main.java:223)
at org.apache.tools.ant.launch.Launcher.run(Launcher.java:284)
at org.apache.tools.ant.launch.Launcher.main(Launcher.java:101)
Caused by: org.eclipse.jgit.errors.MissingObjectException: Missing commit 3a46b07603c41a51750f0468b76666802d4b637e
at org.eclipse.jgit.internal.storage.file.WindowCursor.open(WindowCursor.java:159)
at org.eclipse.jgit.revwalk.RevWalk.getCachedBytes(RevWalk.java:903)
at org.eclipse.jgit.revwalk.RevCommit.parseHeaders(RevCommit.java:155)
at org.eclipse.jgit.revwalk.PendingGenerator.next(PendingGenerator.java:147)
at org.eclipse.jgit.revwalk.StartGenerator.next(StartGenerator.java:184)
at org.eclipse.jgit.revwalk.RevWalk.next(RevWalk.java:435)
at org.eclipse.jgit.revwalk.RevWalk.iterator(RevWalk.java:1322)
... 17 more
