Creating setup installer for Yacy with Nsis from Nullsoft with a Linux Zip
I am trying this installer from NullSoft https://sourceforge.net/projects/nsis/
The Yacy setup must be run as admin in Windows 8 Compatibility which I change the settings before I Zip it.
I just need to create an uninstaller program in QB64 and test then I will share the link in this post. The old zip file is gone
I gave up on installing yacy into program files due to permission problems with a command prompt and not being able to start yacy once setup completes. I starts ok during setup phase.
I now install it to c:\YaCy runs ok.
https://twitter.com/smokingwheels/status/1579415306304622592
Download links for testing dev v 1.926 windows and linux.
Right click save as
Windows run setup icon c:\YaCy
http://165.22.240.144/yacy_dev_1.926_win.exe
Linux unzip run ./startYACY.sh in your folder.
http://165.22.240.144/yacy_dev_1.926_win_lnx.zip
Looks like I’m Donating a 1 CPU 1 GB NextCloud host to the YaCy project for awhile.
My current windows release wont run the setup icon to a custom folder works ok from C:\YaCy.
The Setup.exe and Setup.bat work in any folder ok.
