as I need a watchdog for YaCy in a professional environment, I rely on the checkalive.sh. But it doesn’t work I just set the variables $admin and $YACY_ADMIN_PASSWORD for apicall.sh but checkalive.sh doesn’t restart YaCy if it hangs I also enabled unrestricted admin access for localhost without password but it didn’t solve the problem The problem is as follows: checkalive.sh hangs and doesn’t evaluate the hanging java process as well, so no restart is initiated The only thing I can do is press Control + C to abort the execution of checkalive.sh. Can someone help? I’m on SuSE Linux Enterprise Server. wget and curl is installed.
Greetings
LA_FORGE
